jib size on a typhoon
Randy Haynes
Post by Randy Haynes »
My boat has an over 100% jib on a rolling furler. When sheeting outside the shrouds it won't sheet in very close. Am I doing something wrong? What is the optimum jib size the typhoon? Is very much gained by going over 100%?
Most of my sailing is done in 7-15 mph wind. What is a working jib?
Thanks for your help.
krmh@tca.net
Marino Curati
Re: jib size on a typhoon
Post by Marino Curati »
Randy Haynes wrote: My boat has an over 100% jib on a rolling furler. When sheeting outside the shrouds it won't sheet in very close. Am I doing something wrong? What is the optimum jib size the typhoon? Is very much gained by going over 100%?
Actually we we just discussing this on another post. Your 100% jib sheets should be lead inside the shrouds through the bullseye on the cabintop track. Then back to the winch and cleat. For 7-15, the boat will sail a whole lot better with a Genoa. The Genoa is lead outboard to the track on the gunwale.
Nancy
Post by Nancy »
What size Genoa are people most happy with on a weekender? I'm planning on getting a rolling furler and the sail loft is suggesting a 135 Genoa --is that enough or should I go with 155? I'm sailing the mid Chesapeake.
nenoel@aol.com
sloopjohnl
Post by sloopjohnl »
i like my 150 for light airs, but my sails are hanked on. knowing how light (or non-existent) the air can be on the chesapeake if your sailcloth is heavy enough for a good working jib when rolled out, it may be too heavy for a good 150 when pulled all the way out. this could be why your sailmaker only wants to go to 135. a gennaker or asymmetrical spinnaker would serve you well beyond the 135 if you are into buying sails!
Nancy wrote: What size Genoa are people most happy with on a weekender? I'm planning on getting a rolling furler and the sail loft is suggesting a 135 Genoa --is that enough or should I go with 155? I'm sailing the mid Chesapeake.
Marino
Post by Marino »
My boat still has the original sails. I think the genoa is about 155% although I've never bothered to measure it. I my opinion, the difference between a 135% and up is going to become an issue at the upper wind range of the sail. The boat isn't really a light air performer and when the wind dies, I either drop the hook and read or motor in. I think the 155% would be better simply because the genoa track is so short. You'd get a better angle with a bigger sail. That is unless its been modified.
