I am planning to replace the old Fram filter with a Raco unit with priming pump on my 1GM. Which model have people used? The 215 series seems to be about right but I wonder if 15 gph and a 2 micron filter works ok or if the next size up is better. Any advice or experience will be helpful.
thanks
jim
james.jamieson@yale.edu
Raco filter for Yanmar 1GM
Re: Raco filter for Yanmar 1GM
Jim- I just did this last year, and I used the smallest Racor with the see-thru bowl (120 I think). The 15 gph is plenty for this little engine (being about 20x more capacity than wide open throttle will use up). I noticed a slight increase in WOT speed, probably because the ol' Fram needed cleaning.jim jamieson wrote: I am planning to replace the old Fram filter with a Raco unit with priming pump on my 1GM. Which model have people used? The 215 series seems to be about right but I wonder if 15 gph and a 2 micron filter works ok or if the next size up is better. Any advice or experience will be helpful.
thanks
jim
However, I strongly recommend spending the extra $30 and get the next level up because it has a push button primer pump. What a mistake I made not getting this. Think about all the mess you can avoid when getting diesel into the new filter!
Jeff
jeff.schmoyer@iff.com
The "see through" bowl used to be considered a minus by either the Coast Guard or Underwriters Labs because it--unlike the metal bowl--could shatter. Probably never would happen.... We opted for the metal bowl on our 27'.
Mitchell Bober
RESPITE
CD330
Mitchell Bober
RESPITE
CD330
The metal bowl version is required only on commercial service vessels and all gasoline powered boats. THe plastic bowled Racor are totally legal as is if you are a private boat, and running diesel fuel. I prefer to be able to quickly look and see what the fuel system is doing, rather than have to remove the metal shield first.
Cheers!
Larry DeMers
s/v DeLaMer
Cape Dory 30
demers@sgi.com
Cheers!
Larry DeMers
s/v DeLaMer
Cape Dory 30
M. R. Bober wrote: The "see through" bowl used to be considered a minus by either the Coast Guard or Underwriters Labs because it--unlike the metal bowl--could shatter. Probably never would happen.... We opted for the metal bowl on our 27'.
Mitchell Bober
RESPITE
CD330
demers@sgi.com
