I finally took the boat out for a little spin with the ePropulsion Spirit 1 Evo. It worked great! Typhoon, as you all know, 18.5', 2000 lb, full keel. It moved the boat along easily at 3.5 kt at half throttle, and 5kt at full. Half gives me 2 1/2 hours and full 1 hour. I only need 30 minutes to get in and out of my small canal. Occasionally, with a North wind I can sail out. So range, my biggest worry, does not seem to be a problem. Silent, and I had my hearing aids in!
I used to leave the Yamaha on the mount, this one I'm taking off and putting in the cabin. But the battery comes off, and each part is about 20 lbs, so its pretty easy. Just push the on button, and turn the throttle! It seems stronger than the gas outboard, the propeller is bigger, apparently the electric motors have more torque.
