replacing fuel tank fuel level gauge, CD31
jen1722terry
Post by jen1722terry »
Hi owners,
The fuel level gauge on our CD31 has stopped fuctioning (it stays on "E").
Does anyone know a source for a repacement gauge?
Thanks so much,
Jenn and Terry McAdams
CD31 #33 "Glissade"
Northeast Harbor, ME
Jennifer & Terry McAdams
Kearsarge, New Hampshire
Mahone Bay, Nova Scotia
CD 31 #33 "Glissade"
keneasley
Re: replacing fuel tank fuel level gauge, CD31
Post by keneasley »
Since no one else has responded - I'll chime in.
You've probably already thought of this but -
I have no fuel gauge on my boat, so I keep a logbook of engine hours and how many gallons I put in each time I refill.
This has worked very well for me. The engine uses about 1/3 of a gallon per hour, so the math is easy.
Actually, there is a fuel gauge on top of the fuel tank but there is no way to read it the way the tank is mounted.
Ken Easley
Intrepid 9 Meter - Felicity
Southport Harbor, Connecticut
Skipd
Post by Skipd »
I believe the fuel gauges are all mechanical, it might just need to be cleaned. I added an access port on my 1985 CD30 tank a few years ago and in the process pulled the gauge, cleaned up the gook, replaced it, very straight forward.
Thx
Frenchy
Post by Frenchy »
When mine went bad, I replaced with a Tank Tender. It's a bit expensive, but works great. There are no moving parts, nothing
to break. It's been very reliable. I have the two-tank model and ran the other line to the holding tank.
gonesail
Post by gonesail »
is this the one that sits on top of the fuel tank? take it out and clean it .. mine had all sorts of goop on it.
