Sailing this weekend
jbenagh
Salem, MA
Post by jbenagh »
I sailed with John Ring & Tiara for a bit:
And Christine C got a genniker:
This was at 70 degrees AWA and 7.5-8kt apparent. I think I needed the tack pulled tighter but it's just way too much pressure at that wind speed to get it down under load. I also need to tweak its lead a bit since it was getting behind the furler even with the ATN tacker (that you can't see)
Jeff
Re: Sailing this weekend
Great photographs! That genniker looks massive. I had Doyle make an asymmetrical for Orion and I’ve flown it a couple times so far. I haven’t been able to snap a photo yet but I will sooner or later. Those ATN sleeves are a godsend for a singlehander.
John Ring
Post by John Ring »
IMG_cc file.jpg (293.54 KiB) Viewed 2867 times
That was a GREAT sailing day!
John
CD36 Tiara
