Edson classic model 336 pedestal steerer.
Recently removed from Cape Dory 30. In great condition.
No corrosion at base, repainted, disassembled and comes complete with:
A. Edson 26" Stainless & Teak Destroyer Wheel (used value alone $400?)
B. Richie Compass, recent fluid change,
number dial replaced with larger, easy to read numbers (again, worth a couple hundred bucks )
C. all 4 pulleys on outer radius of steering cable run.
D. Edson bronze quadrant for 1" 1/8 shaft
E. winch handle holder, beverage holders (2)
F. wheel & compass cover
Parts NOT Included and will need to be purchased:
1.Idler / pulley assembly ( for your particular vessel and cockpit - see Edson catalog )
2. sprocket, chain and cable assembly
3. cables for connecting quadrant to chain
You will spend extra dollars for the above 3 items. Hope that's clear enough for you.
$400.00 local pickup Rockland Maine / delivery to Portland Maine add $75.00
Edson Compass/ Binnacle with Destroyer Wheel
- 20230528_081213.jpg (296.37 KiB) Viewed 586 times
Re: Edson Compass/ Binnacle with Destroyer Wheel
Binnacle / compass unit SOLD - !! thanks for helping !!
- wikakaru
Congratulations on selling your gear! Please go to the first post in the thread, click the edit button, and add SOLD to the title so people know without having to read the whole thread that the item is sold. Thanks!
--Jim
--Jim
