Superclean headliner with ZUD
Catherine Monaghan
Post by Catherine Monaghan »
The headliner on Realization, our CD32, was pretty grundgy with blotches of discoloration, especially near the ports, and it had yellowed.
I purchased a product called Zud from our local supermarket (A&P). It is oxalic acid (as found in many fiberglass cleaners) so wear gloves. I usually use the BoatLife fiberglass cleaner when scrubbing the hull but it doesn't compare to Zud (it must be concentrated).
Anyway, you just smear it on with a damp sponge (I used the sponge side of a ScotchBrite pad), wait at least 5 minutes (I did about 1/3 of the headliner, I know it took more than 5 minutes), then wipe it off with a clean wet sponge. I used the sponge side of the ScotchBrite pad for that part too but turned it over and scrubbed with the abrasive side when I met a stubborn stain and it came off.
Realization's headliner is now bright white.
catherine_monaghan@merck.com
Rahway, NJ
Raritan Bay
Dana
Re: Superclean headliner with ZUD
Post by Dana »
Yes...Zud is an old time favorite for copper bottom pans...but if you feel you would like to try something different...try LIQUID Zud (new product on your bronze ports....will crtainly, at least, get the green off if not shine them completely...does take a little elbow grease...
Dana
__________________
Catherine Monaghan wrote: The headliner on Realization, our CD32, was pretty grundgy with blotches of discoloration, especially near the ports, and it had yellowed.
Rahway, NJ
Raritan Bay
darenius@aol.com
Bill
Post by Bill »
You should see what ZUD will do for grey teak!!!
and I just did Rhapsody's interior, with bleach and tide!!! Didnt even think of the Zud!!!!!
Bill
cd25d@rhapsodysails.com
M. R. Bober
Don't get ZUD on plastic cowl vents--BAD SCENE
Post by M. R. Bober »
ZUD wil dissolve the smooth finish on the vents on your Cape Dory (unless you've upgraded to metal). It's also tough on gelcoat as it "softens" the surface.
Mitchel Bober
RESPITE
CD330
thebobers@erols.com
Catherine Monaghan
Oh, I used the liquid form on this product.
I used the liquid.
Rahway, NJ
Raritan Bay
