fuel injection pump, volvo md7a leaking
Greetings, I have a 1981 CD 28 sailboat, and the fuel injection pump is leaking..... any suggestions on getting a rebuilt one or where to have this one rebuilt?
Re: fuel injection pump, volvo md7a leaking
Is it truly the pump that's leaking -or- is it one of the banjo fittings that leaks? If the later, fresh copper, crush washers may solve the problem.Smitty102460 wrote:Greetings, I have a 1981 CD 28 sailboat, and the fuel injection pump is leaking..... any suggestions on getting a rebuilt one or where to have this one rebuilt?
Likely it is the pump as the seals have given up after 40 odd years. Mine seeped for a couple of years before leaking more significantly.
Ask you local diesel mechanic who he recommends to rebuild the pump, as he should know who is reputable. I assume it is the Bosch (not the CAV). To my knowledge, there is nothing special about the pump, so any competent re-builder who does cars, trucks, tractors, agriculture pumps, generators, etc. should be able to order the kit and go at it. That said, the last one I had done (on a '82 Puegeot 505) sure wasn't cheap and took two trips to re-builder to get it to stop leaking.
In my case,1983 MD7B, I lived with the seep, and when the seep became a drip, I chose to repower, thinking it best to put the money and effort into a fresh engine. Depending on the engine condition, your use, fresh/salt water, etc., you may conclude differently. Good Luck.
Steve Bernd
Steve Bernd
Nearly everything you do to that engine is pricy and usually temporary
Danielle Elizabeth
CD30
Danielle Elizabeth
CD30
