Propane installation for CD 33
LouLepis
Post by LouLepis »
Suggestions for installing a propane system on a CD 33? Specifically,
how was it installed in 3 cockpit lazarettes?
Lou Lepis
J_D
Re: Propane installation for CD 33
Post by J_D »
Did you find an answer for this?
Its been a while since this was posted but but I have a CD33 with the propane tank installed in the aft locker. I don't have much appreciation for the set-up as it takes up most of the space in the hatch area but it is compliant to the regs - planning on modifying it one day.
This is an old thread and for some reason I did not see it when originally posted. If you're still out there I designed and installed a propane locker under the aft cockpit sea area. All built to ABYC standards. It's worked out great. Holds three 10lb aluminum propane. Here is the link.
http://www.farreachvoyages.com/projects ... ocker.html
