I would like to hear how autotillers work on a CD 25D?
Is the installation complicated?
Auto tiller for CD 25D
Moderator: bobdugan
- Dick Kobayashi
Re: Auto tiller for CD 25D
1. ST2000 worked fine
2. No Prob with installation
3. Remember you only get about 15 degree deflection of the rudder
4. Must adjust sail and/or course so as to not over power
5. Most helpful when motoring.
6. Worth it, for sure, but it is NOT a wind vane self-steering gizmo
Dick K
CD 25D Susan B #104
Mattapoisett, MA
CD 25D Susan B #104
Mattapoisett, MA
- Joe Myerson
Dave summed it up pretty well.
When my ST2000 was working, I primarily used it to keep the boat headed into the wind while raising or lowering sails, or when I was motoring. Mine has stopped working, and I think it's a problem with wiring, but I haven't solved the problem; probably grounding problem.
--Joe
--Joe
Former Commodore, CDSOA
--Capt. John Smith, 1627
- ch.ocallaghan
I have a Raymarine ST1000+ Tiller Autopilot on my 25D. The installation was relatively straightforward.
To install, you need to:
1) drill a hole and install the power/data Connector on the side of the starboard locker
2) Run 12V power cable from switch in breaker panel to the 12V terminals on the Connector
3) drill a hole for the support pin in the top of the starboard locker
4) drill a hole and install connecting pin in the tiller
If you have a NMEA 0183-capable chartplotter (e.g. Standard Horizon CP190i) you can run another cable from the chartplotter to the NMEA 0183 terminals on the Connector. That will allow the chartplotter to drive the ST1000+ for automatic route following.
If you have a wireless ST1000+ remote control that uses SeaTalk (e.g AP-WRC3 - Madmanmarine.com) you can run another cable from the remote control to the SeaTalk terminals on the Connector. This will allow you to control the ST1000+ using a wireless dongle.
I have an ST1000+ that I use - I burned out the first one I had, though I don't know how old it was as it came with the boat - didn't quite have the tiller balanced as well as I could have (sails/course balanced to get a balanced tiller), so had to replace with new. It works fine, but yes, you have to balance the sails and it has a limited range - when it hits that range it just cycles over and over trying to push or pull the tiller further... hence the burnout.
I also use a 'tiller clutch' for shorter term hands-off work. I can't get that set to steer the boat for long periods of time, but it's enough to grab a sandwich or drink from the icebox or check the gps.
-Alec
-Alec
