Zinc for cape dory 28
arch007
Post by arch007 »
I lost the specifications for my shaft zinc.
It is a collar type zinc for the shaft.
Could someone be kind enough to tell me what are the zinc specifications to order ?
atcowboy
Re: Zinc for cape dory 28
Post by atcowboy »
https://www.amazon.com/gp/product/B0014 ... UTF8&psc=1
This worked for my CD27. The exposed portion of the shaft was very short, so it needed to be high profile vs. the longer egg shaped ones that are a little cheaper.
If you are unable to measure before you pull (I'm assuming the boat is in the water) this zinc is a fairly cheap bet, hopefully it is the right size.
- AT
Sleepwalker
Post by Sleepwalker »
I have used these guys for my zincs. Always quick shipping and no complaints, Also no affiliation.
https://www.boatzincs.com/index.html
