I bought my cd30c October 2019 . The temperature gauge just moves to the beginning of white area after running for two hours. I measured the OHMS on the sensor and I get a difference between when the engine is cold and hot but don’t know if it’s the right resistance . I hooked up a jumper between the sensor wire connection and ground and the gauge went all the way up. I believe it is wired correctly. I suspect it is a bad sensor. From what I read on existing forums the pointer should be in lower quarter of the gauge.
Any suggestions would be appreciated
MD7A temperature gage
Moderator: bobdugan
Re: MD7A temperature gage
Is it possible the sensor is an alarm unit instead of a temperature unit???
Try pulling the sensor and putting it in a pan of water on the stove with a meter connected to the leads.
Check the value as you bring the pot past a boil. If it suddenly maxes out, it's an alarm sensor.
For a relatively small price, you can buy an infrared thermometer to validate a "new temperature" sensor.
- S/V Ethan Grey
I had an overheating issue with mine and wanted to know what temperatures corresponded with the gauge colors. Here is my data. This will vary based on sender and gauge, so I don't know if it will be of any help to you. Eventually I want to change the gauge to one that outputs actual temp versus the white, green, red indicators. At 109F, the gauge was just at white/green mark. At 168 the indicator is at the green/red mark.
David
S/V Ethan Grey
1981 CD 30C, Hull #199
Niceville, FL
CDSOA# 1947
S/V Ethan Grey
Niceville, FL
CDSOA# 1947
Mine is exactly like yours, the highest it ever gets is just into the white. I've been running it that way for 8 years with no problems.
Keith
Keith
