2015 Honda 9.9 Power-Thrust four stroke outboard engine. Original owner. Shows as nearly new. 25” extra long shaft. Pull start. This engine has a 2.25:1 reduction gear turning a powerful 10” diameter four blade propeller. Designed to push heavy displacement type hulls. It moved the 18,000 lb Far Reach at 6 kts on flat water. Perfect for sailboat auxiliary or trolling engine for larger outboard powered fishing boats such as Parker or Grady Whites. Internal alternator with plug in wiring harness to charge a battery.
Professionally made full Sunbrella cover included. Engine meticulously maintained. Largely garage kept. Honda reliability. Starts on first pull. Less than 100 hours of use. Six gallon fuel tank included. More pictures available. Shipping not available. Located in eastern NC. $2000.
Sold—Honda 9.9 HP Four Stroke Power-Thrust Outboard For Sale
- 62017CD8-698C-4738-86F8-ACFACAD7CC20.jpeg (921.55 KiB) Viewed 422 times
- 8F35F8F4-43B9-46F4-849A-18FD9C255232.jpeg (818.73 KiB) Viewed 422 times
Re: Honda 9.9 HP Four Stroke Power-Thrust Outboard For Sale
John,
I am looking to repower my Cape Dory 26. Is your 9.9 Honda still for sale?
Rick
843 846-4250
Rick
843 846-4250
Hi Rick
A couple picked it up yesterday. I did not get a good vibe though. It’s not sold till the check clears. I hope I was not too trusting. There is more to this story but it’s all I will say here. I’ll update the post as soon as, in the words of Miracle Max, it’s “all” sold, as opposed to “mostly” sold.
