Leaking stuffing box access
Green Horn
Post by Green Horn »
Hi everyone,
The stuffing box on my Cape Dory 28 is leaking at a rate of 2 seconds per drip when the engine is running and 20 seconds per drip when it's off. I know I need to get down there with 2 pipe wrenches and tighten the stuffing box nut or worse, repack it. The problem is accessing it through the lazarette. How is it possible to get in there and use 2 wrenches to do this? How do people do it? I don't think I can fit in the lazarette. Has anyone ever bought an abandoned CD28 and found a rotting corpse in the starboard-side lazarette? I feel sure that it has happened. If anyone has experience getting in there please advise how you did it.
My alternate solution is to cut a hole in the cockpit sole and install a bomar access hatch. I don't want to do this, but I may have to. What is the best way to cut the hole? Will a dremel work or should I use something else?
Thanks for your help!
Re: Leaking stuffing box access
The short answer to your questions is to hire a mechanic.
I get to the stuffing box on my CD-30 by laying a camping pad on top of the engine and going in that way. I have installed a dome light and open both cockpit hatches for better light. It is still a tight squeeze to fit in over the engine and not every body type may fit.
As for cutting the hole in your deck; if you have to ask if a Dermel tool is right for the job, you may want some assistance or have someone else do the work. I know a lot of people use Dermel tools for all sorts of jobs but I have always considered it to be a hobby or crafts tool. I don't even own one anymore. I do have a flexible shaft tool that is much more powerful and easier to control but would not use that for your job either. You could easily cut out a deck section with a regular saber saw or a multi tool. Keep in mind that cutting the hole is only a small portion of the job. You will also need to rout out and seal the core then seal and fasten the hatch in place.
Having a mechanic replace the packing may be a much cheaper and easier option than installing a hatch, Steve.
Green Horn
Thanks for the advice Steve. The problem with boat mechanics is that they don't want to work on a small old boat. Anytime I call one all I get is "we're slammed right now" etc. But if it's a big expensive boat they do seem to find time for them. But I do agree that it might be the best way to go if I can find someone who will do it.
Bryce
Post by Bryce »
To simply adjust the packing gland, I use a long screw driver/pry bar and a hammer. Lay down head first in the starboard lazarette and you should be able to reach both nuts. To replace the packing requires I go all the way in head first. Not a fun job.
Green Horn
Hi everyone,
Well the stuffing box has been tightened and I was even able to get into the lazarette and out of it. It required 3 tools and a mechanic to make this happen. - a pipe wrench to hold the stuffing box in place because the 2 nuts were frozen (it appeared to have been a long time when this was done last). We wedged the pipe wrench up against the hull and then used 2 wrenches to bust the nuts free. The direction to open the locking nut is towards the port side on my boat. Leak issue solved.
Green Horn wrote:Hi everyone,
Great job. Some of the lockers and spaces you have to access in a small boat require all your ingenuity.
