My wife and I inherited my dad's old O'day Daysailer several years back that I grew up sailing on, and we had a great couple years with it, but recently had a baby and were looking for a similar, daysailer-type boat that would be a little sturdier and safer for our little one to grow up sailing on, especially where we sail now. I've always loved the timeless lines, teak, and feel of the Typhoons, and we finally snagged one this year!
The boat is hull #1184 from 1974, and all in all the boat is in very good shape. There are a lot of little (and a few big) tweaks and repairs that I'll want to do over the next season or two, and I'm looking forward to sharing my progress here and on the Project board. I've learned a ton from lurking around the board, and am so appreciative of the amount of time and thought everyone puts into their responses! The CD association and this board is such a hidden gem of sailing and maintenance knowledge.
As far as I see it, I have 4 main project areas with the boat:
1) modernizing and adding hardware where needed
2) repairing bad sealants, old fixture holes, heavy crazing spot
3) reinforcing old backing plates/nonexisting backing plates
4) dealing with the teak work
For (1) Hardware:
- There's no fairlead for the furling line, and the previous owner just ran it over the cabin top and cleated it to the starboard cleat on top of the cabin, I'd like to run a few fairleads along the top deck and install a cam cleat on the side of one of the coamings so keep it a little more organized and out of the way.
- The mainsheet setup is probably original and is a little tired, I'd like to modernize it though I don't think I'd go full traveler. The other typhoon I've sailed on had a fiddlehead block, but I find it really disorienting to have to pull *down* on the main sheet to release it. Not sure what the best other options would be... If it was a single block system, it would also involve removing/patching/painting over the old block points.
- There are no cleats/cams/blocks or anything else attached to the boom for reefing the main, and being able to easily reef is very important to me. Also, I'd like to install a reefing hook and some earrings through the luff reefing grommet. Question - for the clew reefing line, can I just install one block at the end of the boom that would act as both downhaul and outhaul, or do I need one line pulling down, and one line pulling aft? Also, not totally sure how to sew the reefing earrings securely...
For (2) sealants and fixtures:
- The previous owner removed the bow pulpit, but rather than patching and painting the holes, looks like he just put the screws back in. I hope he bedded them! Though the deck feels very firm... I'd like to remove the screws, epoxy the holes, and paint over them. My concern is whether or not just painting that area will look terrible, or if it will force me to repaint the whole top deck
- There's one spot near the starboard cleat and top deck jib lead that is pretty badly crazed. I'd like to clean it up, but I don't know the best course of action. Is it deep enough that I'll need to Dremel it all up, epoxy, and paint? For something like this, am I actually gel coating, not painting?
- The teak toe rails look like they were sealed with silicone, and it’s peeling up all over the place. How would you recommend resealing along the toe and rub rails? Do I need to remove the rails to properly reseal them, or is there a better sealant I can use along the seams like silicone, but not silicone?
- In the second picture (with the back top deck cracking), you can also see a void between the cabin and the coaming. Is this OK, or should all the points where the coamings meet the fiberglass should there be some sort of sealant? If so, which?
For the (3) backing plates:
- The starboard shroud failed a couple years back and the boat was demasted. The mast has been repaired, and the previous owner put a nice sized stainless steel backing plate on the starboard side, but it doesn’t seem like any other backing plate has been inspected or updated, maybe ever. For peace of mind, I’d like to cut a larger inspection hole on the port side, and add a new G10 backing plate for the port shroud. And I figure, while in backing plate mode, I might as well put new ones in for the fore and aft stays as well, and behind whatever new mainsheet block I decide on. Speaking of enlarging inspection ports, I’d like to replace the little 4 inch on behind the tiller with a 6” port, so I can actually get in there and put the new backing plates in. The piece of wood behind the engine bracket mount could use replacing, too.
For the (4) teak:
- The coamings and the cabin teak rails are varnished but tired, and the toe rails are all bare. I’d like them to match, and actually enjoy varnishing, so I figure I’ll take everything off that I can in the fall, and varnish in my basement over the winter. I don’t want to deal with the headache of taking the toe rails off, so I’ll tape them off and varnish them in the spring. Question - for re-attaching all the coamings and other teak rails, how do you recommend bedding those? Butyl tape, something else? Do they not need it? Also, a couple dozen teak bungs on the toe rails are either deteriorating or totally gone, if I replace them and hammer in new ones and varnish over them, does that count as sealing, or do I need to do extra?
- Related to the sealant issue, I imagine replacing and resealing where the old silicone is will be connected to my varnish job.
That’s “all” for now! Excited to dig in to these projects.
