batteries and solar setup for 24v outboard
Moderator: bobdugan
- Megunticook
I'm starting to make plans and budget for an electric outboard to replace my 4-stroke. The motor I'm looking at, Elco Ep-5, is 24v.
Ideally, I'd like to have an electrical system aboard that doesn't require shore power to recharge. Since it's a small boat, I'm thinking of putting in just a pair of 12v AGM batteries wired in series. Probably only have 100-150 amp-hour capacity. Wondering if anybody has something like this and what sort of gear they're using, lessons learned, etc.
Biggest challenge may be getting a 24V solar panel that will fit the boat...
Re: batteries and solar setup for 24v outboard
You could keep the batteries in parallel for charging and then switch to series for using the outboard.Megunticook wrote:Biggest challenge may be getting a 24V solar panel that will fit the boat...
- Megunticook
That's an interesting idea, hadn't thought of that. Would need to be some heavy-duty switches to handle the current, it sounds like this motor can pull up to 100 amps.
I noticed that my little portable panel (40W) that I have installed now has an open circuit voltage of 21v. Gensun makes some device that can boost the voltage. Be worth looking into. Of course I'd need a lot more than 40W to recharge that bank after use.
Have the admit the idea of a "zero-carbon" boat is pretty appealing...
- drysuit2
- Location: Segue, 1985 Cape Dory 26 Hull # 15 Port Washington NY
That is an awfully big and heavy set up for a typhoon. What didn't you like about the Torqeedo?Megunticook wrote:I'm starting to make plans and budget for an electric outboard to replace my 4-stroke. The motor I'm looking at, Elco Ep-5, is 24v.
Just read your post today. This is what I have done:Megunticook wrote:I'm starting to make plans and budget for an electric outboard to replace my 4-stroke. The motor I'm looking at, Elco Ep-5, is 24v.
I have used a Torqeedo Cruise 2.0 as my primary motor on my Capri 22 since 2011. It was moored for several years using just a 100 W 12 vdc solar panel with a Genasun Boost controller that provides the appropriate voltage change to properly charge a nominal 24 volt battery. The solar panel is mounted on some 1-inch railing above the transom.
I recently upgraded the solar panel to 160 watts and the batteries to Lithium (first using Battle Born, now Torqeedo). The lead acid batteries are less expensive at first, but have a much shorter life in years.
When my lead acid batteries failed near the end of one season, I purchased a Torqeedo Travel 1003C. It pushed my Capri 22 very well to almost 5 knots. I regularly use it for my O'Day 19.
John
CD25 #622
CPDE0622M78E
"You are not going to find the ideal boat. You are not even going to have it if you design it from scratch."
~ Carl Lane
CD25 #622
CPDE0622M78E
~ Carl Lane
- Megunticook
drysuit2 wrote:That is an awfully big and heavy set up for a typhoon.
Typhoon Senior--significantly bigger than a Typhoon. It could be as small as 2 additional batteries, maybe 100-150 lbs. or so total. The motor itself is comparable in weight to the Yamaha F4 that's in there now.
drysuit2 wrote:What didn't you like about the Torqeedo?
Cost! But I could be persuaded that it's worth it. I think the motor is $4K plus more for the Lithium Ion battery.
- Megunticook
Wow...how much does a Capri weigh? I was thinking my boat would need the Cruise 2.0 RL, which they say is equivalent to a 5hp gasser.jepomer wrote:When my lead acid batteries failed near the end of one season, I purchased a Torqeedo Travel 1003C. It pushed my Capri 22 very well to almost 5 knots. I regularly use it for my O'Day 19.
I do like the idea of using more advanced batteries though.
- drysuit2
OK so I wrote up my experience so far this year here..https://drysuit2.blogspot.com/2019/05/i ... board.htmlMegunticook wrote:drysuit2 wrote:That is an awfully big and heavy set up for a typhoon.
And I've attached the cost spreadsheet. the Elco is $2,600 plus the battery, the Torqeedo is $2,000 with the standard Battery. Though I will probably buy a spare next season, because the prices are dropping for LiIon.
I understand that for some 3.5 HP just is not enough to make them comfortable. For me it is. Remember that I don't cruise, and have only used my engine three times this season.
It sounds like you think you need the 5 or 6 HP models. if so than yes the 2.0 Torqeedo 5HP is $4,000.
