Inland Cape Dory 27 ****SOLD ****
Slainte, our beloved 27, is for sail. Slainte is now out of the water and in her steel cradle and under her full cover.
Price has been reduced to $13,300. This is a nice boat and it sickens me that we are unable to use it. Someone will get a nice boat for less than half of what we have in her.
Aft Quarter.JPG (9.53 MiB) Viewed 456 times
1980 Cape Dory 27, a Nice Fresh Water Sloop
Hull # 185
ID#: CPDJ0185M80J
Coast Guard Documented #1257949
Inboard YSM8 8HP Yanmar Diesel Engine with 2014 Racor 500FG Turbine Fuel Filter with Water Separator
In the water at Harbor Point Yacht Club, West Alton, MO (15 miles North of St. Louis)
Fiberglass Hull and Topsides
Full Cut-away Keel with internal lead ballast
2015 Hull was stripped and Sealed with VC-17 then Painted with Ablative
Dimensions:
LOA: 27 ft 1 in
Beam: 8 ft 6 in
LWL: 20 ft 0 in
Maximum Draft: 4 ft 0 in
Displacement: 7500 lbs
Ballast: 3000 lbs
Sail Area 365 square feet
Starboard bulkhead.JPG (8.55 MiB) Viewed 456 times
Accommodations:
Number of berths: 2 singles in main cabin + 2 in V-berth
Number of heads: 1 Airhead Composting Toilet
Two burner Alcohol Stove with cutting board top
Stainless Steel Sink
Ice Box
Fresh Water: 24 gallon Polypropylene Bow Tank under V-berth
Fuel Tanks: (12 Gallons)
Accessories:
Cabin from Aft.JPG (6.93 MiB) Viewed 456 times
Six Bronze opening ports
Dorade vent with Bronze exterior/red interior scoop
Nicor Day/Night Plus Solar Vent
2010 Simrad Multi Display and Tri-Ducer for Speed, Depth and Temperature
Aqua Saturn Compass
Raymarine ST-2000 Tiller Pilot
Sails and Hardware:
2013 UK Halsey 2+2 Battened mainsail
2016 Tides Marine Strongtrack Sailtrack System
2016 Mack 130 Genoa on roller gear with sun protection strip
Ash Shroud Rollers
2012 Garhauer Rigid Boom Vang
2012 Garhauer Mainsheet Traveler
All sails and covers stored indoors during the winter
All standing rigging Is in Good shape
All Running rigging replaced 2014 and 2016
Lifelines replaced 2010
Electrical Equipment:
2015 Entire AC re-wired From Shore power inlet to New AC Panel
30 amp Shore power inlet with interior AC GFCI outlets
50’ Marinco shore power cord
2012 Pro Mariner Pronautic 1210P battery charger from shore power
Dual Batteries
2015 New 2 Ga wiring from Batteries to DC Panel
2014 New BlueSeas 12V Fuse Block and Ground Buss
Attwood Electric Bilge Pump and Whale Gusher 8 manual bilge pump
Covers:
2016 Marine Blue Sunbrella Mainsail Cover matching tiller cover and sheet bags
2010 Complete Winter Cover from The Canvass Store
2016 New Cabin Cushion Upholstery (main cabin & V-berth)
All cushions stored indoors during the winter
Please use email (tjr818 at lycos dot com) or PM link
