HELP ! yesterday discovered the hot water heater on our beloved "Diversion" has developed a leak. Since it's got some age on it the mechanic says to replace it but that is no easy task , as the heat exchanger & oil cooler be removed , & should probably also replace the heat exchanger. Hot water tank is 6gal, Atwood. Anyone have experience in replacing hot water heater is such a tight spot. (Volvo diesel TAMD 41B, 200hp) Thanks, Wally Stone
Stonedeyhle@juno.com
Power 28'flybridge, water heater/exchanger
