I applied KiwiGrip to the cabin top. There was a slight chance of rain which was worrisome, but otherwise the conditions were good with overcast skies, 74°F and 50% RH. White KiwiGrip doesn't have much contrast, when first applied. It becomes off-white over time as can be seen on the main deck in the picture. Now, I can continue re-bedding fittings, which provides a real sense of progress.
KiwiGrip
Re: KiwiGrip
Hi Jonathon, I see what happens now. I guess I should have let your post run a while before I cut you off. Or I should post under a different category. Sorry
