Running coax between liner and hull...
s2sailorlis
Post by s2sailorlis »
At some point my CD22 had a coax running thru the deck and back to the area near the companionway..of course 4 years ago I removed the wire but totally forgot how the wire was run.,,
The thru deck area is accessible just under the mast area...
For the life of me I can't figure out how to run the coax RG-8X between the liner and deck...
The first pix show the steaming deck wire, the other wire runs aft above the liner...
From what I can tell it's bone dry in that area with no rust weeping from the mild steel plate..
______________
Rick
1984 CD22
