are there any suggestions on how to best support cabin top sag under the mast step of the CD Typhoon...really need help
also the guy helping to rebuild my boat cut out the frozen open stop cocks and does not like the way the drains are designed cutting sharp angles from cockpit to thru hull...any suggestions?
this boat was not taken care of so a lot of deck cracks...and in cockpit...do I sand down and epoxy and awl grip...want to launch soon...painting her, re did bottom, and all the wood and rebedding fittings...yikes...was not to be a project boat to start with and needs a lot of tlc
best suggestions for compass...a board mount?
sailing with a motor attached...isn't that too heavy on the transom?
cabin top sag prevention solutions, drainage, cracks...yikes
Re: cabin top sag prevention solutions, drainage, cracks...y
Sailors with a lot more experience, knowledge and skill than I possess will soon weigh in but on the topic of the "cabin top sag" I think most sailors have added a compression post.
This CDSOA thread is a starting place.
http://www.capedory.org/board/viewtopic ... on#p179307
If you use the search button with the words "compression post Typhoon" you get several hundred more posts and suggestions.
Good luck with your project. I am sure it is well worth your efforts.
As for the cockpit drain hoses, if you use the "Search" button and type in "cockpit drain hose Typhoon" you will find 90 plus discussions of how to deal with drainage issues, cockpit seacocks, hoses, etc., including these two threads:
http://www.capedory.org/board/viewtopic ... se+Typhoon
http://www.capedory.org/board/viewtopic ... on#p185149
Do you have the original bronze outboard mount? If so, sailing with a light engine is no problem. I had British Seagulls on both of my Typhoons and weight was not an issue. Just don't get HP hungry... it doesn't take much to reach hull speed on a Ty with the proper prop.
