bowsprit repair for limited rot. Is epoxy the solutiom -
jack Kelley
Location: 30 ft. CD cutter 1982 "Marpessa" Hyannis Yacht Club
Post by jack Kelley »
Damage is under the steel plate.
Jack Kelley
Re: bowsprit repair for limited rot. Is epoxy the solutiom -
A photo with a detailed description would be helpful.
jack Kelley
Jim: Thank you for your response. I have a picture on my computer in an email. What address to I forward this to?
Regards,
Jack Kelley
Jack Kelley
jack Kelley wrote:Jim: Thank you for your response. I have a picture on my computer in an email. What address to I forward this to?
Regards,
Jack Kelley
Post it here for all to see. Someone may have the specific knowledge to provide a valuable response. If you have never posted a photo this may help.
http://www.capedory.org/board/viewtopic.php?f=2&t=14638
riveredge
Post by riveredge »
I just did an epoxy repair on the teak bowsprit on my CD28. At the suggestion of someone much more knowledgeable than me, I took thin scrap strips of teak and laminated them in with thickened G-Flex Epoxy. I was fixing trapped moisture softened teak on the starboard side where the toe rail and rub rail connect to the bowsprit.
jack Kelley
Riveredge: Thank you for your response-it sounds like the method I can use. Is G Flex made by West? I would appreciate any other info on your repair-sanding -planing-for cosmetic appearance.
Jack
Jack Kelley
riveredge
Post by riveredge »
G-Flex is a West product. I thickened it with teak sawdust so it is dark teak colored. I just cut the strips of teak to fit the gap and saturated them with epoxy before filling in the gap with them in the order I had dry-fitted them. I cut the last piece to fill the gap closely but it wound up being recessed by about 1/16". So I'm thinking of carefully making one more piece of teak "veneer" shaped like the face of the gap and epoxying it on to really nicely finish the patch. I may not get to that before launch Wednesday but I'll post a photo of the repair either finished or almost finished if you like.
jack Kelley
Riveredge: Your comments are valued-thank you so much!
Jack Kelley
Jack Kelley
jack Kelley
Riveredge: I am ready to start repair! Since I have a quantity of West #610 in cartridge form and easy to dispense via caulking gun - I thought I would use that up. How thick are your teak strips? Do you think the #610 would work as well as the G Flex? Again, I appreciate your comments!
Jack
Jack Kelley
riveredge
Post by riveredge »
I'm not familiar with 610. I used G-Flex because the guy recommending said it is flexible when cured so its good with wood which has natural flex in it. The strips I used were various from about 1/8" X 1/2" to 1/2" square with lengths cut to fit the gap caused by water intrusion. The last piece that would show I cut to exactly fit the gap. Its about 1/8" thick and is about 1" or so at its widest. See attached photo. The patch is in the bowsprit behind the broken toerail. A bad repair of the toerail by someone before me probably caused the water intrusion. Not pictured is the final repair where I added one more fitted slice of teak and epoxied the toerail back together.
riveredge
Post by riveredge »
Here's the finished repair. Not perfect but not bad.
jack Kelley
Great Job! Did you allow the epoxy to cure between the strips or did you lay up everything at once to complete your repair?
Jack
Jack Kelley
riveredge
Post by riveredge »
I did it all at once. As far as I know epoxy cure is a chemical reaction between resin and hardener as has nothing to do with air.
jack Kelley
Thanks again Riveredge-GREAT JOB!
Jack
Jack Kelley
