My cabin sole was showing its age and needed some attention. I had no intention of stripping, staining, and applying a topcoat as such a project is beyond my skill (patience) level. The original veneered plywood is actually a good grade of cabin sole ply as the holly inserts are slightly raised from the teak. A feature I've not seen in more modern boats. That is the feature which assured a degree of slip resistance in original installations.
I lightly sanded my sole with 150 and 220 grit sandpaper. More for "tooth" than to remove the existing finish. I used a 5" orbital sander and a hand sanding block. I applied two coats of Interlux Schooner. It was chosen because it is a traditional amber varnish which I hoped might mask some of the numerous "imperfections" acquired over the last 32 years. I chose to use gloss rather than satin finish, primarily because a gloss base with a satin topcoat is deemed superior to numerous coats of gloss. I'm not certain at this time that I will apply a satin topcoat. I'll decide by the time spring arrives.
Cabin sole refurbish
- Lightly sanded original finish
- image.jpeg (418.81 KiB) Viewed 997 times
- Two coats of Interlux Schooner
- image.jpeg (374.91 KiB) Viewed 997 times
Re: Cabin sole refurbish
Really, really nice Jim
You just added to my "To Do" list.
Thanks. Steve Laume stopped by this afternoon and he didn't laugh (out loud) so it can't be too bad looking.
in a previous life I used to restore antique homes. When refinishing floors, often pumpkin pine, typical schedule was 3-4 coats of gloss followed with 2-3 coats satin. it produced an almost 3-dimensional look with depth.
CD 30c #42
S/V "Bluesails"
+ 41.69989
-70.027199
S/V "Bluesails"
+ 41.69989
-70.027199
There will be no laughing at such a noble effort and a job well done. It is always great to get those first couple of sealer coats on. Now it is just a matter of building up an additional 6 or 8 coats and it will be magnificent. Or maybe 1 or 2 more in the spring and then just keep sailing with a nicely sealed sole.Jim Walsh wrote:Thanks. Steve Laume stopped by this afternoon and he didn't laugh (out loud) so it can't be too bad looking.
It looks great, Steve.
