Located in South Dartmouth, MA. PHOTO BELOW Still in the water (as of 9/17/18). Owned and sailed this wonderful boat primarily in Buzzard’s Bay, Vineyard and Rhode Island Sounds since 1998. Boat has been well-maintained and serviced by the Concordia Company since 2001.
GRATEFUL has been a great joy and has given us wonderful sails and experiences with family and friends. The boat comes with the high-standard accruements and design that one would expect of this most desirable cutter. The roller-furling main has made the boat safer, more efficient and easier to sail with all lines handled from the cockpit and infinite reefing positions. Because we could change the sail area with little effort, over time we learned that the boat handled better, was more comfortable and equally fast with less sail out, even in modest strength winds. And, the Universal 30 diesel has been very, very reliable and efficient to operate. We burn—at the most—40 gallons of diesel per season.
For a cruising couple that loves interesting ports and anchorages—and great food—this boat fills the bill with a spacious salon, three burner stove and oven, and ample ice box and storage spaces. By the way, this combination works well also for longer distance voyages.
The deck surfaces are showing signs of wear with surface cracks in the gel coat (but have been there for all the years we have owned Grateful!).
Significant improvements include:
new Garmin GPS/Radar combination 2016
new headsail 2015
new alternator 2015
replaced starboard water tank 2015
replace marine head and faucets 2015/16
strip and repair toerail 2014
bottom stripped, new barrier coat, sand /paint 2013
installed electric bilge pump 2018
renewed engine circulation pump 2012
new main sheet fiddle block 2011
added raw water strainer 2007
convert main to Factor 7CF90 roller furling with NEW main sail in 2006
overhaul engine 2005 (run approximately 100 hours per year since then)
Specifications
Hull 138
L.O.A.: 35' 4"
L.O.D. 33' 1/2"
L.W.L.: 24' 6"
Beam: 10' 3"
Draft: 4' 10"
Displacement: 13,300 lbs.
Ballast: 5,500 lbs
Sail Area: 561 sq. ft.
Instruments: Data Marine depth finder and wind indicator as well as Garmin GPS/Radar
AC System for Shore Power
Three Fresh Water tanks (84 gallons)
Designer: Carl Alberg
Year Built: 1986
Price: $42,000 (IMAGE BELOW)
Contact: Come see her in the water now.
lewcarter@comcast.net or 508-542-5242
1986 Cape Dory Cutter For Sale
- preview.jpg (35.83 KiB) Viewed 710 times
