(4) Brownell SB4 Sailboat Stands - Like New - $360
Vcoast
Dover, NH
Post by Vcoast »
These stands were used only indoors and only for a short duration of a few months while working on my Cape Dory Typhoon Restoration Project, and have been stored indoors since. They still look new, and are being offered as a set of (4).
They're ideal for smaller keeled sailboats. Unlike taller stands, where additional blocking is needed under the keel to accommodate, with these your boat stays low, making it much easier to work on, in, under and around.
Tech specs: American Made by Brownell Mfg. Center pipe angles are 23 degrees, Factory Blue, Plywood tops are 12" x 12" painted Gray and swivel. Solid Steel threaded center rods make for easy adjustments under load. Adjustment range is 24"-36".
New stands retail for upwards of $150 each, ($600 for 4) making this set a bargain at $360 for all (4).
These stands are located in Dover, NH 03820
SB4 Boatstand.jpg (1.26 MiB) Viewed 268 times
How can my boat account be empty, I still have more checks?
