(4) Boat Stands for Sale - Used for Typhoon
Vcoast
Dover, NH
Post by Vcoast »
(4) Brownell SB-4 Sailboat Stands - Like New Perfect Condition
These stands were used only indoors to support a Cape Dory Typhoon during restoration so they look absolutely brand new. If you have a similar restoration project, and want to work on a small sailboat in your garage, these stands are just what you need. Or, if you don't have a trailer and put your boat on stands, these will keep your baby nice and low and easy to work on. Here are the tech specs: American Made (of course) Center pipe angles 23 . Plywood tops are 12" x 12", painted Gray, and swivel. Solid Steel threaded center rods make for easy adjustments under load, the rod is removable for Stackable convenient storage. Adjustment range is 24"-36".
If you need to see pics, just Google the model number, mine look just as shiny as the new ones for sale, only difference is; new stands retail for $150 each, and these can be had for $90 ea., so a total savings of $240. Asking $360 for the set of 4
These stands are located in Dover, NH
All (4) stands look like this
SB4 Boat Stand 2.JPG (1.5 MiB) Viewed 344 times
How can my boat account be empty, I still have more checks?
Carl Thunberg
Re: (4) Boat Stands for Sale - Used for Typhoon
Post by Carl Thunberg »
Funny, I also live in New Hampshire (Hopkinton) and have 4 of the exact same jack stands. Did you break into my barn? :wink:
Sir Isaac Newton
Vcoast
Dover, NH
Post by Vcoast »
I did. I also borrowed your chain saw. BTW, it needs to be sharpened before my next project. Keep a close eye on your snowblower, mine is getting a little finicky after the punishment it endured last season. :D
