I never thought this day would come, but I purchased an Intrepid 9 Meter last fall, so "Puffin" is for sale. 1986 Cape Dory Typhoon Senior, 22', w/ 2 axle Loadmaster float-off trailer, and steel A frame mast raising system. 2008 Nissan 4 stroke in the well, professionally maintained annually. The motor rotates in the well, making her agile around docks, and the prop never cavitates. Always fresh water. I sailed her on Lake Superior. 2007 Mainsail by Nathaniel Wilson (see "Sailmaker's Apprentice" appendix B) 2014 135 genoa, 2013 heavy air jib, 2010 Bi-radial drifter, original main, working jib, and gennacker by Thomas Clark (see also "Sailmaker's Apprentice Appendix B). Gennacker is a work of art. Jibs are hanked on, dedicated sheets. There is also a roller furler and genoa I took off in 2005. Locking foredeck Lewmar hatch has exterior handles - great for sail changes. Main has 2 reef points, the first controlled by Harken single line reefing. Halyards led to cockpit. 6 winches. Mid-boom sheeting w/ traveler on bridgedeck. Interior and cabintop grab handles. Double life lines. Bow pulpit. Jib dousing line. VHF, depth, (speed not working). Porta pottie. Original interior cushions - good. 2 batteries port to starboard mounted. Switch 1, 2, both. Fortress anchor pulpit mounted. Chain/rope rode, hause pipe. Shore power, cord, GFI outlets. 2013 Sta-set X halyards and traditional Sta-set main sheet. Boom vang. Manual and elec bilge pumps. Dry boat. Lots of storage under berths. All berths 6' 2".
$9975. Minneapolis, Minnesota. Dave H. 612-750-1834.
