Cape Dory 31 Hull ID Number
pat strohmeyer
Post by pat strohmeyer »
Does anyone know if the Cape Dory 31 has a second Hull ID Number inside the boat somewhere?
Pat
JWSutcliffe
Re: Cape Dory 31 Hull ID Number
Post by JWSutcliffe »
Only HIN I am aware of on mine is on the transom.
Skip Sutcliffe
CD31 Oryx
pat strohmeyer
Skip,
Tanks for your reply.
Pat
Zeida
Location: 1982 CD33 "Bandolera II" Hull #73Key Biscayne-Miami, Florida
Post by Zeida »
Pat, my 1981 CD33 has the usual hull number on the transom, but when I first bought the boat I also found in one of the bottom lockers in the V berth, a 2-ft. x 3" piece of board that also had a long number. I had wondered what that could be until I realized the numbers were the same as those in the transom. Maybe somewhere inside your boat there may be something similar.. :?: FWIW.
Zeida
barfwinkle
Post by barfwinkle »
Rhapsody has a second Nr. in her starboard locker. According to the USCG there should be another Nr. Some where.
Fair winds.
Bill Member #250.
swhfire21
Post by swhfire21 »
Our 26 has the HIN written/painted on hull inside the port cockpit locker if that helps. About 2-3 inch tall lettering.
Steve
Pleasant Journey, Morgan 35
Previously:
'85 CD 26, Hull No. 30
'74 Typhoon Hull No. 789
Jim Cornwell
Post by Jim Cornwell »
Sure these big numbers aren't USCG documentation numbers? After a long search I stumbled upon Yankee's documentation number encapsulated in resin beneath one of the CNG tanks in the lazarette, very well hidden.
pat strohmeyer
Jim,
Thanks for the info.
Pat
Cathy Monaghan
Post by Cathy Monaghan »
swhfire21 wrote:Our 26 has the HIN written/painted on hull inside the port cockpit locker if that helps. About 2-3 inch tall lettering.
That's where it is (besides on the stern) on our CD32 as well. It's up high, you have to stick your whole in there and look up to find it.
Cathy
CD32 Realization, #3
Rahway, NJ
Raritan Bay
CDSOA Associate Member #265
Rahway, NJ
Raritan Bay
