Excellent condition, fresh water, 1995 Honda 2 hp, 4 cycle outboard. Long shaft used on Typhoon for the last 4 years in Greenwood Lake, NJ/NY. Previous owner also a fresh water sailor. One pull start, with internal gas tank. All fluids changed at end of each season and stored indoors. New propeller installed last year/includes old propeller as a spare. Note: Starts in gear, no neutral, motor turns 180 degrees for reverse. Some wear on cover, see pictures. $495. Local pick up only, northern NJ. Send PM
Pictures: https://drive.google.com/folderview?id= ... sp=sharing
Honda 2hp, 4 Cycle-SOLD Thanks
Re: Honda 2hp, 4 Cycle
Local pickup is easier but would be willing to ship with purchaser paying for the UPS store packing and shipping charges. Call cell 862-262-2390.
Andy
Andy
- M. R. Bober
I have that same great little engine, EXCEPT mine turns 180 degrees for reverse.agogates wrote:Excellent condition, fresh water, 1995 Honda 2 hp, 4 cycle outboard. Long shaft used on Typhoon for the last 4 years in Greenwood Lake, NJ/NY. Previous owner also a fresh water sailor. One pull start, with internal gas tank. All fluids changed at end of each season and stored indoors. New propeller installed last year/includes old propeller as a spare. Note: Starts in gear, no neutral, motor turns 360 degrees for reverse. Some wear on cover, see pictures. $495. Local pick up only, northern NJ. Send PM
Mitchell Bober
CDSOA Founding Member
Mitchell:M. R. Bober wrote:I have that same great little engine, EXCEPT mine turns 180 degrees for reverse.agogates wrote:Excellent condition, fresh water, 1995 Honda 2 hp, 4 cycle outboard. Long shaft used on Typhoon for the last 4 years in Greenwood Lake, NJ/NY. Previous owner also a fresh water sailor. One pull start, with internal gas tank. All fluids changed at end of each season and stored indoors. New propeller installed last year/includes old propeller as a spare. Note: Starts in gear, no neutral, motor turns 360 degrees for reverse. Some wear on cover, see pictures. $495. Local pick up only, northern NJ. Send PM
Pictures: https://drive.google.com/folderview?id= ... sp=sharingOf course, it can be turned 180 degrees in either direction,
Mitchell Bober
I (and perhaps hundreds if not thousands) are disappointed in your above post. We have come to await with great anticipation your statement at the end of each post that says "Sunny Lancaster (Where_________________________ fill in the blank) Va". It is part of the fiber and fabric of the CDSOA board.
What happened
Good catch, I must open the textbooks again. I will change it to 180 degrees!
Andy
Andy
