Typhoon Engine Mount
John Peck
Post by John Peck »
I'm trying to remove the Engine mount..It has an anti theft type of thing that goes thru the hull....Anyone have the same setup???What's the best way to take it off....Thanks John
flyguy@nobleknights.com
Patrick McCarthy
Re: Typhoon Engine Mount
Post by Patrick McCarthy »
John I would like to help you however I need a better explanation of the problem. Is it a lock on the engine or the mount? What year is the boat? If it is th original mount that came with the boat it should be pretty easy. You could call me at 212-745-2240 if you would like to talk about it.
pfmccar@us.ibm.com
Patrick McCarthy
John I would like to help but need more information. What year is the boat? You could call me at 212-745-2240 if you would like some help
