Hello,
If any of you know where we might purchase a good used mast for a CD 28 in Eastern Canada or Maine, please let us know.
We would also consider buying a new extrusion of the right dimension and mounting the hardware from the old mast.
Jennifer and Terry McAdams
Mahone Bay, Nova Scotia
jen1722terry@gmail.com
1-902-624-0790
WANTED: MAST FOR CAPE DORY 28 (used of new)
Jennifer & Terry McAdams
Kearsarge, New Hampshire
CD 31 #33 "Glissade"
Re: WANTED: MAST FOR CAPE DORY 28 (used of new)
You've probably already looked here, but just in case.....
http://www.rigrite.com/Spars/Spartan_Sp ... _mast.html
Check with these guys to see if they have the right mast section. If so, they are great to work with and could do anything from supply a blank to a complete mast set up, Steve.
https://www.dwyermast.com/families.asp? ... Name=Masts
I do not believe they do.Steve Laume wrote:Check with these guys to see if they have the right mast section. If so, they are great to work with and could do anything from supply a blank to a complete mast set up, Steve.
I contacted them about a replacement mast for our CD27, which I believe has the same dimensions as the 28 and 30, they did not have a spar with the same diameters
