I need to replace a part of my sole on my Cape Dory Senior..the v-berth section only. appro. 25" x 22".
I'd thought I check and see if any members might have a small peice of the teak and holly sole left over they may want to sell. I live in Salem Ma.
Thanks, David.
Wanted: Teak & Holly Sole......
Re: Wanted: Teak & Holly Sole......
Try Boulter Plywood in Somerville, MA. They should be willing to sell you a partial sheet.
Duncan Maio
s/v Remedy
CD27 #37
Bristol, RI
s/v Remedy
CD27 #37
Bristol, RI
David,
I have a piece of Teak & Holly ply that may be the size you're looking for. However you may be able to get what you need directly from Boulter since you're already in Mass.
Two years ago I ordered a half sheet (2’ X8 ’)of ½” teak and holly plywood from Boulter Plywood Corp in Massachusetts to replace the cabin sole in my CD-22. The cost was $120 for a half-sheet and would’ve been $155 shipping (to Georgia) for the intact 2’ X 8’ sheet. They cut the 2 X 8 sheet into at 65”, so shipping charges were only $40. Boulter was the only supplier I found at the time that would sell a half sheet.
The piece I have is 24 1/4" wide by 31" long. This may not work for you if the size you need is 25" wide.
Cheers,
Warren H.
Cheers,
Warren H.
