Typhoon seacocks
Clem Dunkley
Typhoon seacocks
Post by Clem Dunkley »
Has anyone replaced the gate valve seacocks on a Typhoon? I am looking at an older model with the original corroded seacocks and it looks like it might be a job to remove them.Also, I am not sure if there might be a problem installing the newer ball-type, particularly after reading about some of the problems with replacing the scupper drain hoses. Any comments would be appreciated.
cedunk@gte.net
randy
Re: Typhoon seacocks
Post by randy »
we replaced the entire cockpit drain system on our cd- 19 typhoon weekender by using a high-speed air disksander with a disk cutter and removed the entire thru-hull fittings and seacocks and tubing. this was not easy because of cramped space. bought all new fittings at west marine.. randy (p.s. did not replace cockpit drain fittings.)
wrnewman@hotmail.com
