CD 22 machine screw size
Does anyone know the exact size of the machine screw in the seacock drain hole ---seacock is in the cockpit drain plumbing.Hardware store can*t match the one I bring to them. I*ll call Spartan if no one is specific Thanks Roger
- bottomscraper
#12-24 Bronze Odd Size!
I assume you mean for a Spartan Seacock. This topic has come up a few times. The screws are #12-24 and should be bronze.
They are not something you will find at your local hardware store in bronze. Some people have drilled out holes larger and tapped so that a
more common size screw can be used. It appears Fastenal might have some.
Previous Topic:
http://www.capedory.org/board/viewtopic ... ock#p67021
Fastenal:
http://www.fastenal.com/web/products/de ... ku=0179415
Previous Topic:
Fastenal:
Rich Abato
Nordic Tug 34 Tanuki
Southern Maine
http://www.sailmahalo.com
Southern Maine
Re: CD 22 machine screw size
Thanks Rich. I*ll follow your suggestion
I had good luck here... http://www.boltdepot.com when I replaced the thru hulls on my typhoon. they have a variety of bronze fasteners; you might give them a go... hank frazier
