scupper drains cd 25
pete faga
Post by pete faga »
while replacing the gate valves and hose leading to the cockpit scuppers the fiberglass fitting that the hose attatches to broke off on one scupper.I checked the archives and did not see any info.the cd manual has a bronze fitting listed.any ideas on a secure fix. thanks in advance. pete
tartansailor
Re: scupper drains cd 25
Post by tartansailor »
Model No. 356453 (see link below) and some careful drill & fit.
http://catalogs.westmarine.com/WebProje ... wma&from=2#
Viam Inveniam Aut Faciam
John Ring
Post by John Ring »
Hi Pete,
When I swapped out the gate valves for new ball valves on my 1978 CD25 years ago, I found the plastic tailpiece screwed onto the gate valves were smaller in diameter (1-1/2"?) than the bronze scuppers (1-5/8"?) glassed into the cockpit. The hose used was sized properly for the scupper, but a bit too large for the old plastic tailpiece. The 1-5/8" hoses were just clamped on over the unusually large bump in the old 1-1/2" plastic tailpiece. The new 1-5/8" hose I used fit the old glassed in scuppers, but was also a bit too large for the new 1-1/2" bronze tailpieces on my new valves. I ended up using a spacer and some sealant on the new bronze tailpieces to get the hose to fit right.
I've seen diesel mechanic use large diameter heat shrink tubing (adhesive backed) to step up 1-1/5" mufflers to accept 1-5/8" exhaust hose coming off a 1-5/8" exhaust manifold. Maybe you could do something like that on your tailpieces if you find they don't match.
Have you found a mast for Grace yet?
Best,
John
CD28 Tantalus
pete faga
Post by pete faga »
Thanks dick and John for the info.I had the tails repaired/fiberglassed new hoses for the sink to the new seacocks.goodbye old gate valves.hopefully the mast will be repaired tomorrow.
bobred
Post by bobred »
Is there a special tool in order to remove the bronze scupper
so I can replace the hose?
