You can see the blue striped hose above the water pump and the black adapter on it. The useless strainer was gone before I hit the water and a Groco now lives on the side wall.
I have seen that the copper pipe plugs up first, causing the dreaded Volvo redzone temp gauge, so I'll be addressing it this winter.
I'm making two bronze fittings to adapt the water pump to take 1/2" hose directly. I'll fab a saddle bracket to clamp the two adapters to the pump and seal properly. The first adapter is complete here, along with an older pipe used on another engine.
Following that, I have 1/2' O.D. tubing that will get a tee fitting to replace the worn/ crimped copper tubing. A few new rubber gaskets, and I should have a solid, non wallet flattening cooling solution.
What are others doing when the copper tube goes south?
This is also a spare. Mine's crimped worse.
