For Sale, 2008 Nissan 9.8, Four Stroke Outboard
Steve D
Post by Steve D »
For Sale, 2008 Nissan 9.8, Four Stroke Outboard, $1245.00
See a video of this engine running at: http://www.youtube.com/watch?v=XSyyyQxHdx8
Image Image
Image Image
• Lightest Outboard in Class @ 81.5 lbs
• Advanced Digital CD Ignition System
• Low Oil Pressure Warning Indicator
• ESG Over Rev RPM Limiter
• High Grade Marine Alloy Construction
• Stainless Steel Water Pump Housing
• Zinc Coated Water Passages
• Sacrificial Zinc Anodes + Trim Tab
• Forward Mounted Gear Shift Selector
• Twist-Grip Throttle with Tension Control
• Adjustable Steering Friction Setting
• Advanced Fast-Idle Choke Feature
• Start-In-Gear Protection
• Thermostatically Controlled Cooling
• Advanced Cross Flow Induction System
• Shallow Water Drive; 6 Trim Positions
• Quiet Through-The-Propeller Exhaust
• 3.1 Gallon Fuel Tank / Fuel Line
• Safety Lanyard Cut-Off Switch
• Operating Manual & Emergency Tool Kit
Specifications
Meets or exceeds all Federal, EPA emission standards
California C.A.R.B. three star rating for ultra low emissions
Engine Type: 9.8hp, 4-Stroke, 2-Cylinder, SOHC
Displacement: 209 cc (12.8 cubic inches)
Bore and Stroke: 55 x 44 mm (2.17 x 1.73 inches)
Full Throttle RPM Range: 5,000-6,000 RPM
Ignition System: Digital CD Ignition
Induction Scavenging: SOHC
Valves per Cylinder: 2
Fuel Delivery: Single Venturi Carburetor w/ Advanced Choke
Fuel Type: Unleaded Gasoline (87 octane)
Oil Type: SAE 10W-30 or SAE 10W-40 (SF, SG, SH, SJ)
Oil Capacity: 27 fl. oz. (800 ml)
Lubrication: Wet Sump
Starting System: Thru-Cowl Manual Start
Alternator (OPTIONAL): Optional 12V 80W 6A (installation required)
Cooling System: Water-Cooled, Thermostatically Controlled
C.A.R.B. Rating: Ultra-Low Emission (3-STAR)
Saltwater Rated: YES
Trim Positions: 6
Gear Ratio: 2.08:1
Gear Shift: Forward-Neutral-Reverse (front mount shifter)
Propeller: 8.5" Dia. X 9.0" Pitch 3-Blade Aluminum
Fuel Tank (INCLUDED): 3.1 Gal. Fuel Tank + Quick Connect Fuel Line
Transom Height: 15" Short Shaft
Weight: 81.5 lbs (37 kg)
Sells new for $1,885.00
Steve D
Nissian Outboard
Post by Steve D »
Still available.
bluemoose
Re: Nissian Outboard
Post by bluemoose »
Steve D wrote:Still available.
Not once you call me :-) I'll just need to figure out how to get out to Virginia to get it.
