Hello all,
I had my topsides compounded and waxed this Spring. The result is beautiful and gives me even more pride in having a Cape Dory.
Sunday the rubrail of my dinghy bumped the topside and left a very small blue smudge mark. I cannot even feel it if I rub my finger across it, but I know that it is there. Does anyone have a suggestion of how to remove the smudge without leaving a dull spot on the wax job.
JBA
topside rub removal
Removing the smudge
JBA,
The easiest thing to do is to use the mildest, least abrasive rubbing compound you can find, on a very soft cloth. Use just your finger to gently rub the small area. You could also use a little damp baking soda or a little soft scrub the same way. It's only slightly possible that you'll get the smudge off without damaging the wax. In any case, it's EASY to just re-wax the area using a good quality car or boat wax, following the instructions on the can.
Another possibility is to buy a can of "cleaner wax", which is two products in one. It will remove the smudge and leave the area freshly waxed.
Good Luck!
Good Luck!
Regards,
Troy Scott
Troy Scott
- Bob Ohler
3M Cleaner/Wax
I read last night that Hinckley uses 3M Cleaner/Wax. I have used this product as well. I would give it a try on your smudge.
Bob O.
Bob O.
Bob Ohler
CDSOA Member #188
CD30B, Hull # 335
sv Aloha Spirit
CDSOA Member #188
CD30B, Hull # 335
sv Aloha Spirit
