Hello all,
Last fall I removed the two small wood sections around the rudder post that kept the water out of the bilge of my Typhoon. I am ready to re-install but need some guidance. If I coat the bottom of the wood with 4200, will that do the job? Any other suggestions? Thanks, JBA
rudderpost leak
Moderator: bobdugan
- Sea Hunt
I used BoatLife Lifeseal sealant at the wood sections around rudder post in the cockpit with good results.
http://boatlife.com/life-seal.html?SID= ... 9664e9524a
Robert
Robert
Rudderpost leak
Thanks Sea Hunt, I appreciate your suggestion JBA
