Hello all:
The spreader bases on my TY are welded at a right angle to the mast. How can I get the bi-section of the shroud without bending something? I checked the archives but could not find this specific issue addressed.
JBA
spreader base
Try a little emory cloth
There's supposed to be some slack where the spreader bar fits into the socket, like Bill said. Is there some crud in the socket? Alternatively, you could try a little emory cloth on the spreader bar itself. It should not be a tight fit.
In structural engineering terms, this is intended to be a "pin-connection" that is incapable of transferring any bending moment to the socket. If it becomes a "fixed" connection, then you're probably going to bend your spreader bar. The spreader bar is supposed to be a compression member only. I hope this is helpful.
Sir Isaac Newton
Sir Isaac Newton
