cd27 hull #1 for sale
stuartc
Post by stuartc »
Hull #1 is for sale.8 instead of 6 ports. Needs lots of work. Probably new chainplates,definite cockpit sole. Only 2-3 soft spots on deck which are easily accessed from interior. Consultation with a glass fabricator suggests this boat should have a compression post. The interior, diesel, and tanks have all been removed. Either the original 1 cyl yanmar or a 2GM20 are available as well. The gear is there for an Edson wheel, alas the wheel, pedestal and sails have been stolen. A Yacht Specialties pedestal and wheel are included but would probably be more work than picking up a used Edson.(have seen several in the $300.00 to $600.00 range.) There is no mystery to any of this work but a lot of man hours would be required. The 1 cyl yanmar is of questionable quality. The 2 cyl yanmar is a take out-acquired from a reputable source. It will fit and be an easy install if the cockpit sole was partially removed and replaced after engine install.$2000.00 for boat. $1800.00 for 2gm20. The 3000lbs of lead in the keel and the bronze ports alone are worth the asking price. call John at 508-846-0273 or 508-398-4053 Boat etc are located in S. Yarmouth, Ma on Cape Cod.
