Hi, I have a CD motorsailer w/westerbeke 46 hp.I want to replace the racor fuel unit.What racor unit is used for the westerbeke 46?I`m talking about the racor unit,not the filters.
thanks
Westerbeke 46 / racor system ?
Delaware
Richard
1990 CD Motorsailer Hull #46
There should be two filters, an on engine filter (secondary) and a Racor (primary). I don't know which Racor you have so can't recommend a specific filter element.
Generally a 30 or 10 micron is used in the primary filter. The secondary on-engine Westerbeke filter is a 15 micron as that is what the engine needs. If your tanks are old and potentially dirty a 30 mic would be fine..
My brother has had good results with the Dahl filters. His motor is a Perkins 4-108 that sounds about the same size as the Westerbeke 46.
http://www.oilsandlube.com/dahlfilter.htm
