Warren Kaplan wrote: Even with the box wrenches which fit nicely on some of the bolts, I can see that access to the others may be a bear!!! Stay tuned!
Warren and all,
Something more to look at to reduce the influx of grey hair and frown lines on the temple.
You say that the box wrenches fit nicely on SOME of the bolts. Sometimes those sneaky boat builders throw us curve balls with the use of both SAE and Metric hardware.
There is a trick I sometimes use in one of those "When All Else Fails" situations. When I have to resort to the Braille system to remove one of the nuts that I cant see but can only feel, I whip out a handy kind of wrench.
It is a box wrench with a built in ratchet in its head. Once you get it positioned over the nut, you just crank away. No need to remove it to reposition it for continuous removal. Just flip the button on the head to reverse the ratcheting action.
http://www.stanleytools.com/showPic.asp ... midres.jpg
http://www.stanleytools.com/default.asp ... Y=91%2D617
BTW, you can buy them separately or by the entire kit.
It is just my personal feeling, but to undo a screw head with a nut on the other end, I try to just hold back on the screw head whether it is slot or Phillips head. I apply the torque to the nut. I find it better doing it this way, you use less force to hold the screw head than trying to turn it. Friction helps some in preventing the screw from turning. This method also helps prevent stripping the screw head beyond use.
Apply anti-seize on the threads when making up the unit.
Good luck. I've been in your shoes before.
