Shaft Log--CD36 redux
Moderator: bobdugan
- M. R. Bober
I just had a survey on a CD36. The aft end of the shaft log "disappears" into the fiberglass. The surveyor and I are concerned about the apparent absence of hose clamps on the aft end of the hose. The hose deflects under pressure so it would seem that there is not solid tube under it.
A quick search of this site show a few variations on the shaft log theme. CD must have secured the shaft log somehow. Does anyone know how they did it?
Thanks in advance,
Mitchell Bober
Sunny Lancaster (currently in the state of confusion), VA
Thanks in advance,
Mitchell Bober
CDSOA Founding Member
Hi Mitchell -
Here's a shot of my old shaft log:
[img]http://lh4.ggpht.com/_2Lg5unxPjB8/Sm9zM ... %20028.JPG[/img]
You can see the marks from the buried hose clamps.
In this pic, you can see where the trailing edge broke out when the shoe was removed:
[img]http://lh5.ggpht.com/_2Lg5unxPjB8/Sm9zB ... %20027.JPG[/img]
That is in part because of the way this whole contraption went together. The shaft had no interior tubing -- simply the hose. At the aft end, it tied onto (by hose clamp) a bronze shoe that extended partway into the hull and accepted the aft end of the hose. That shoe is bolted onto the hull -- but poorly so IMO. It was done with lags on my 330. I replaced one of them with a carriage bolt and big washers inside. The lower bolt remains a lag for now because there is no good interior access (below the shaft) and I couldn't convince the yard to do this job as I wanted it done
By way of context: when I purchased the boat, I immediately hired the yard at the p/o's marina to replace the cutlass bearing. This grew into a reshaft, shaft log, etc etc etc. In the process numerous issues with the engineering of this part of the boat were revealed. That combined with the fact that the yard's work was atrocious -- despite its stellar reputation -- has left me with a number of nagging issues in this area. i suspect I will dig in there myself sooner rather than later to rework the entire job.
Hope some of that is useful. Good luck!
Matt
Matt
- Bill Cochrane
s/v Phoenix
Last year I had the yard install a dripless seal in place of the Spartan stuffing box. This was a bit of a major job...the shaft, shaft log, and cutless bearing were all replaced in the process.
<img width ="540"src="http://i52.photobucket.com/albums/g37/w ... oxBA-1.jpg" >
Before the change, the stuffing box hose was very tight against the aft end of the space, but there were double clamps on both the shaft log end and the stuffing box end. The aft end did sort of "disappear into the fiberglass"...not sure where else it would go!
<img width = "540" src = "http://i52.photobucket.com/albums/g37/w ... oxBA-2.jpg" >
The new shaft log is fiberglass; I'm not sure about the old one but would guess it was the same. Edit: after reading Matt's post, I can't be positive that the stuffing box hose was not connected to the bronze fitting, but on the new installation a fiberglass shaft log is clearly visible.
There are also two bolts, visible above and hidden below the shaft, that hold the bronze fitting on the outside of the hull which secures the cutless bearing. I believe both the shaft log and cutless bearing are friction fit; there is also a screw port and starboard, running athwartships, that penetrate the afore mentioned bronze fitting and secure the cutless bearing in place.
- M. R. Bober
Thanks to both of you.
Bill the aft end of the hose has no visible hose clamps nor is there room for any hence the "disappeared into the fiberglass" remark. Sorry I have no photos.
When I had to replace the shaft and cutlass bearing on RESPITE (CD330) the yard noted difficulty in the process due to a "hidden flat hose clamp" at the aft end of the shaft log.
Mitchell Bober
Sunny Lancaster (where adders can multiple on a log table), VA
Mitchell Bober
- Matt Cawthorne
Hull # 79
Mitch,
There is no rubber hose on my boat. The stuffing box is threaded directly onto the bronze tube that holds the cutlas bearing. There just isn't room for the rubber hose, and the transmission and cutlass bearing are so close that there is not much opportunity for the shaft to wobble much. What this means is that if your engine is out of alignment, or the shaft is bent, the stuffing box will leak. Whether the engine shaking is enough to be a problem is up for debate. It does not seem to be for me. My boat is hull number 79. I am not certain why they never put a rubber hose on it. Perhaps they ran out of hoses that week and delivered it that way. My boat has more room between the coupling and the stuffing box than the pictures above.
Matt
Matt
- David van den Burgh
Ditto
FWIW, ditto Matt's reply. Ariel is hull #7.Matt Cawthorne wrote:Mitch,
Matt
