Cold weather in Texas should we be concerned
captalex
Location: Cape Dory 30 B Cutter "Something to stand on"
Post by captalex »
Anyone concerned or have ideas on what may freeze and cause problems with these upcoming freezing temps....I have 50/50 in the engine but what about the water tanks and heater or even the head what about the batteries? My boat has never been frozen so this could be an interesting yet costly experience!
Neil Gordon
Post by Neil Gordon »
The batteries won't freeze. Cars up north all have batteries and they're just fine.
Water, on the other hand, will freeze (and expand in the process). What freezes when depends on how low the temp goes for how long and the quantity of water being frozen. Small amounts (e.g., hoses) freeze sooner than larger amounts (e.g., tanks. Note that even where OJ lives, lakes freeze over but they don't freeze solid.
If you're looking just at overnight temps just below freezing, you're probably safe.
jerryaxler
Texas freeze
Post by jerryaxler »
If the boat is in the water and the freeze is not deep, don't worry. However if the boat is on the hard, I would put non-toxic antifreeze in the water system. Those narrow water lines are easy to freeze and then split from the expansion. If the freeze is prolonged, I would winterize the head and empty the seacocks all around since they can be distorted by expansion on freezing.
What ever happened to global warming?
Fairwinds and following seas,
Jerry Axler
