I have 6 h.p. o.b. long shaft.I neen some sources/ideas on how to mount?
thank's
john
cmp0507k@gte.net
motor mount for o.b. on typhoon ?
Re: motor mount for o.b. on typhoon ?
John I had owned a CD Typhoon, actually the same one twice. But for the motor mount contact: Spartan Marine
Robinhood ME 04530
(207) 371-2542
(800) 325-3287
they have what you need. ONe other thing, you'll find that the motor will drag in the water when on starboard tacks. I would stow the motor below until I needed it, and hope that i didn't need it. GGood luck.
smooth sailing,
Puffin II
CD25" Hull 217
sail number 318
saltzma@ibm.net or saltzman@aecom.yu.edu
Robinhood ME 04530
(207) 371-2542
(800) 325-3287
smooth sailing,
Puffin II
CD25" Hull 217
sail number 318
john barton wrote: I have 6 h.p. o.b. long shaft.I neen some sources/ideas on how to mount?
thank's
john
John,
Try Handy Boat in Falmouth, ME. They make a fine cast bronze motor mount for considerably less than the folks at Spartan. One caution, do not overload either of the mounts as they will deflect under load.
Lee
lhodsdon@msn.com
Lee
thank's
john
lhodsdon@msn.com
