Hi Everybody,
Just a heads up......
Your web team is in the process of moving this web site. The process should be completed over the next few days. We already have the new site up and running, are in testing mode and everything currently looks good.
While this is happening, we will probably have to shut things down for awhile. The online store will be shut down then the message board. We anticipate that it will take several hours. It is possible (but unlikely) that some users might take as long as 24 hours to see the board again, due to the time needed for the IP address change to percolate through the web...
When the move is complete the change should be transparent, the URL will be the same and everything else should look and work the same way as well.
We'll let you know, here, the date and time that's been scheduled for the move to take place.
Cathy
Webmaster - CDSOA, Inc.
IMPORTANT message about this site....
- Cathy Monaghan
- Cathy Monaghan
Monday
The current plan is to start the finalization of the move of our web site on Monday, June 29th at 1:00 p.m. EDT/10:00 a.m. PDT. The web site, including the message board and the online store will be inaccessible during the move. We anticipate that the site will be down for about 4 hours (hopefully not longer than that) but it may be even longer before some of you will be able to access site. It would be a good time for you to go and enjoy your boat.
- Cathy
- Cathy
- Cathy Monaghan
Took a little longer than expected....
Hi Gang,
Well it took us a little longer (5 hours instead of 4) than anticipated but we finally got the web site moved. If you're reading this, obviously you've found your way back to our site but for others it may take even longer before they're able to access it due to the change in servers and IP addresses which needs to update across the web.
If you notice anything missing or not working, please send an email to: webmaster@capedory.org
and one of us will address it.
Cathy (Webmaster - CDSOA, Inc.)
Ray Garcia (Assistant Webmaster)
Bob Dugan (Datameister)
