varnish
bizhough
varnish
Post by bizhough »
I recently bought a Cape Dory 14. Can anyone tell me the best varnish to use on the mahogany gunwales and seat?
Biz Houghton
tartansailor
Epoxy + Varnish
Post by tartansailor »
Assuming you take it down to bare wood, the recommendation would be to dry thoroughly, then epoxy coat to prevent moisture absorption which results in expansion and contraction with changes in humidity. This expansion is what cracks varnish.
I like Interlux Schooner because it is phenolic based.
krebsie
Post by krebsie »
Yes Epoxy/Varnish works well. Initially on my teak I did 3x coats west system epoxy followed by 4x coats varnish. Then every season I maintain by 2x coats of varnish in the spring to block uv.
Hope this helps
bizhough
Post by bizhough »
Thanks for the input. I can't wait to get to work this weekend: warm and dry!!!
Biz Houghton
