Mast diameter -- CD25D and CD26
Peter Kozup
Hull #42 Sandusky Ohio
Post by Peter Kozup »
Does anyone out there know whether the diameter of the mast on a CD25D and a CD26 are the same? The sail area is the same for both boats, and I would guess that the same mast was used for the two boats, but I'm not sure. I am having a rigid boomvang made for my CD26, and the fellow making it has made one for a CD25D before and therefore has the measurements for the brackets. But he does not have the measurements for the 26. My boat is a two hour drive away and I'd rather not drive there to measure it if I don't have to. Hence my question!!
If the diameter of the two masts is the same, then I won't have to worry about going to the boat and making a template, but if it isn't then I will. Does anyone know? If not, is there anyplace I could find the answer? Thanks for your help.
Cathy Monaghan
Mast dimensions...
Post by Cathy Monaghan »
Yes, they should be the same. Here's the info for your mast. It includes the dimensions.
http://www.rigrite.com/Spars/Spartan_Sp ... _mast.html
