I would appreciate some help understanding which numbers and units are used to calculate this ratio. My understanding is that this ratio helps describe relative livliness of a boat, but I have never been able to reproduce published numbers. Thanks in advance.
Craig Urquhart
Satu CD27 #272
Satu@gwi.net
Sail Area Displacement Ratio
Re: Sail Area Displacement Ratio
___________________________________Craig Urquhart wrote: I would appreciate some help understanding which numbers and units are used to calculate this ratio. My understanding is that this ratio helps describe relative livliness of a boat, but I have never been able to reproduce published numbers. Thanks in advance.
Craig Urquhart
Satu CD27 #272
Try S/D=SA/(displ/((64.05)^2/3)) where SA= sq ft of working sails
displ=weight of boat in lbs.
S/D<14......you have a motorboat
S/D~14 to 16.5 (cruiser)
S/D>16.5....you have a racer
darenius@aol.com
Gerr, "The Nature of Boats"
The reference in the subject line not only gives the formulas for many of these ratios, from SA/D to prismatic coefficient, but also does a good job of explaining their meaning in an introductory and fun way.
Craig,
You can use this <a href="http://www.image-ination.com/sailcalc.html">sailboat calculator</a>. It will provide you with more information than just the SA/D of your boat. Remember to convert inches (twelfths) into decimal values (tenths) before entering your data into the calculator.
catherine_monaghan@merck.com
CD32 Realization
Raritan Bay
CD32 Realization
Raritan Bay
Craig Urquhart
Satu CD27 #272
